passing value to tcl
- 5 years ago
thx. seem "exec" would work but everytime i try
exec quartus_sh -t top.tcl 5 it just freeze quartus
May I know whether the suggestion from Heiko help in your case?
Do you need further help on this?
Richard Tan
- s002wjh5 years ago
it help on linux side, but what about tcl console in quartus?
when i try quartus_sh i got these errors
Error:invalid command name "quartus_sh"
Error: while executingError:"unknown_original quartus_sh -t top_all.tcl 5"Error: ("eval" body line 1)Error: invoked from withinError:"eval unknown_original $cmd $args"Error: (procedure "::unknown" line 7)Error: invoked from withinError:"quartus_sh -t top_all.tcl 5"- Heiko5 years ago
If you're running it from the tcl console the quartus_sh is not a valid command. Because (*I think) the tcl console in the quartus user interface is actually just the quartus_sh executable running in interactive mode.
To call quartus_sh from the tcl console you could use the exec command.
Following your example
exec quartus_sh -t top_all.tcl 5
Not sure if that is the most elegant solution to your problem. But it should work.
