8 years agoPassing of pointers through channels
Here I want my kernel2 to be autorun kernel and as we cannot pass any arguments to kernel2, we are passing an address of a buffer from Kernel1 to Kernel2 through channel and trying to access the cont...
8 years agoAutorum kernels do not have an interface to host or external memory and you cannot access external memory directly from an autorun kernel, even if you pass the pointer through channels. Instead of passing the pointer, you should pass the actual data through channels to the autorun kernel. Autorun kernels should be accompanied by another non-autorun kernel that reads data from external memory and streams it to the autorun kernel via a channel.
