11 years agoPartial reconfiguration problem in quartus 2
Hello every one , I just work on a project to design modular partial reconfigurable FPGA from ALtera kits. my eventual quartus II (13.1) does not support PR because of License problems .furthermo...
11 years ago --- Quote Start --- From reading your post, I'm not sure you sufficiently understand partial reconfiguration. You shouldn't be having any license problems - you either have a license for your chosen device family or you don't. Partial reconfiguration also won't work with two configuration files from different projects. Have a read of the partial reconfiguration ip core (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/megafunctions/ug-partrecon.pdf) user guide. I hope it helps you understand PR a little more and which device families support it. Cheers, Alex --- Quote End --- Hello Alex, thanx for respond , actually , multiple persona functionality ist not possible whit eventual version. you are right. i am so new to use partial reconfiguration . BTW thnx for advice :)
