8 years agoParameterizing ALTERA_FP_FUNCTIONS
Greetings I would like to use " Multiply Add " operation of ALTERA_FP_FUNCTIONS IP for an arria10 based project. The "Arria10 Native Floating-Point DSP Intel FPGA IP User Guide" that I referred,...
8 years agoThank you for reply.
After Your reply, I realized that I had confused with 'Multiply Add' operation of DSP template with the same of Arithmetic templaBte of floating point IPcores and referred wrong user guide. Heartfelt sorry for that. I attached the screen shot of the IPcore with its parameter editor window, which I intended about. I tried to know its operation through "floating point IP user guide", but unfortunately not much information available in it. So please let me know the mode of operation of the particular IP. In other words I just want to know whether it is possible to implement the operation Y = [A * B] - C with the " Multiply Add " operation of ALTERA_FP_FUNCTIONS IP available in the arithmetic template of basic function library. Thanking you Anish
