8 years agoParameterizing ALTERA_FP_FUNCTIONS
Greetings I would like to use " Multiply Add " operation of ALTERA_FP_FUNCTIONS IP for an arria10 based project. The "Arria10 Native Floating-Point DSP Intel FPGA IP User Guide" that I referred,...
8 years agoHi Anish,
--- Quote Start --- I wish to perform the third operation for the implementation of an algorithm. But when I try to Parameterize the above said IP, didn't find any option to choose the specified operation. Please let me know how to parameterize the Multiply Add operation of ALTERA_FP_FUNCTIONS IP for executing equation out = (ay * az) - ax. --- Quote End --- Ensure In “Parameters” window, 1. DSP Template : Multiply Add 2. View: Register Enables 3. Click on Mux in front of input Ax & ensure Ax is connected as lower input to Mux. 4. Click on Adder near to “Out” & ensure it is in Subtraction mode 5. If you want Chain Out then click on “Chain Out mux”. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)
