11 years agoRather than a counter could I do a for loop? The following is my code section with the shift-register to serialize part which is implemented at the bottom:
// Wires and registers related to data capturing wire capture_clk; reg [31:0] capture_data; wire capture_en; reg [4:0] slowdown; wire capture_full; reg capture_open; reg capture_open_cross; reg capture_has_been_full; reg capture_has_been_nonfull; reg has_been_full_cross; reg has_been_full; // Data capture section // ==================== always @(posedge capture_clk) begin if (capture_en) capture_data <= user_w_write_32_data; // Bogus data source // The slowdown register limits the data pace to 1/32 the bus_clk // when capture_clk = bus_clk. This is necessary, because the // core in the evaluation kit is configured for simplicity, and // not for performance. Sustained data rates of 200 MB/sec are // easily reached with performance-oriented setting. // The slowdown register has no function in a real-life application. slowdown <= slowdown + 1; // capture_has_been_full remembers that the FIFO has been full // until the file is closed. capture_has_been_nonfull prevents // capture_has_been_full to respond to the initial full condition // every FIFO displays on reset. if (!capture_full) capture_has_been_nonfull <= 1; else if (!capture_open) capture_has_been_nonfull <= 0; if (capture_full && capture_has_been_nonfull) capture_has_been_full <= 1; else if (!capture_open) capture_has_been_full <= 0; end // The dependency on slowdown is only for bogus data assign capture_en = capture_open && !capture_full && !capture_has_been_full && (slowdown == 0); // Clock crossing logic: bus_clk -> capture_clk always @(posedge capture_clk) begin capture_open_cross <= user_r_read_32_open; capture_open <= capture_open_cross; end // Clock crossing logic: capture_clk -> bus_clk always @(posedge bus_clk) begin has_been_full_cross <= capture_has_been_full; has_been_full <= has_been_full_cross; end // The user_r_read_32_eof signal is required to go from '0' to '1' only on // a clock cycle following an asserted read enable, according to Xillybus' // core API. This is assured, since it's a logical AND between // user_r_read_32_empty and has_been_full. has_been_full goes high when the // FIFO is full, so it's guaranteed that user_r_read_32_empty is low when // that happens. On the other hand, user_r_read_32_empty is a FIFO's empty // signal, which naturally meets the requirement. assign user_r_read_32_eof = user_r_read_32_empty && has_been_full; assign user_w_write_32_full = 0; // The data capture clock here is bus_clk for simplicity, but clock domain // crossing is done properly, so capture_clk can be an independent clock // without any other changes. assign capture_clk = bus_clk; async_fifo_32x512 fifo_32 //FIFO created using Xilinx FIFO Generator Wizard ( .rst(!user_r_read_32_open), .wr_clk(capture_clk), .rd_clk(bus_clk), .din(capture_data), .wr_en(capture_en), .rd_en(user_r_read_32_rden), .dout(user_r_read_32_data), .full(capture_full), .empty(user_r_read_32_empty) ); reg Q_en = 1'b0; //starting value is 0 because first 32bit is I reg [31:0] data_outI; reg [31:0] data_outQ; reg I; reg Q; integer counter; always @(posedge bus_clk) begin if(Q_en == 1'b0) begin //To output to I signal data_outI <= user_r_read_32_data; for (counter = 0; counter < 32; counter = counter + 1) begin //output to pins I = data_outI[0]; data_outI <= (data_outI >> 1); Q = data_outQ[0]; data_outQ <= (data_outQ >> 1); end Q_en <= ~Q_en; end else if(Q_en == 1'b1) begin //To output to Q signal data_outQ <= user_r_read_32_data; for (counter = 0; counter < 32; counter = counter + 1) begin //output to pins I = data_outI[0]; data_outI <= (data_outI >> 1); Q = data_outQ[0]; data_outQ <= (data_outQ >> 1); end Q_en <= ~Q_en; end end assign PS_GPIO_ONE_I = I; //Assign Pin I assign PS_GPIO_TWO_Q = Q; //Assign Pin Q
