8 years agoOutput Timing Constraints
Hello, I'm working on a design that is ending with registers stage followed by multiplexers. I would like to know the proper way to constraint the output, i.e. the MUX timing constraint, to ope...
8 years agoif its going to an output pin, I highly recommend using the output regsiter. This way you can use the set_output_delay constrain to skew the clock. If it has logic before the pin, the skew will be unknown, or at least less deterministic.
