9 years agooutput doesn't toggle when simulating with other entities in Modelsim
Hi, I'm working on a vhdl testbench to simulate the behaviour of an I2C bus. I started with an original code (written in verilog) that works, made some changes to it an simulate it's behaviour as a s...
9 years agoIts actually a Verilog syntax problem.
The end of your "sending your read data" always block, you have this code:
end else
state <= 8'h07; // signal
sda_o_e <= 1'b0; // other_signal
end
Note there is no begin..end around the assignments. That means that only the state asignment is in the else, and the sda_o_e <= 1'b0; is in the original start-stop if block. This will mean this assignment to 0 always overrides whatever else was assigned. its a bit of a gotcha in verilog that you're allowed to code without begin..end, but you must remember that only 1 line of code gets included. Putting begin..end around it fixed the problem.
