Fan_T_Intel's avatar
Fan_T_Intel
8 years ago
Out of memory: Quartus_sta is using 230GByte memory.
My Quartus prime standard edition v17.1.0 reports error during STA, however mapper and fitter and assembler finished successfully.
following is the error:
<internal_error>
<executable>quartus_sta</executable>
<sub_system>MEM</sub_system>
<error>*** Fatal Error: Out of memory in module quartus_sta (231339 megabytes used)</error>
<date>Wed Aug 15 15:01:45 2018</date>
<version>Version 17.1.0 Build 590 10/25/2017 SJ Standard Edition</version>
</internal_error>
Any clue what might be causing that?
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Hope this may help you ,
    You may see this error when compiling large designs targeting high density devices using the Quartus® II 32-bit software.
    Compiling high density designs may consume greater than the 2 to 3 GB of memory resources available per process on 32-bit operating systems.
    To resolve this issue, use the Quartus II 64-bit software with a 64-bit operating system.
    https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd10202009_168.html
    For recommenced RAM size based on device family refer below link.
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn_qts_dev_support.pdf
    Anand Raj Shankar
  • Fan_T_Intel's avatar
    Fan_T_Intel
    Hi Anand,
    I have --64bit option, so it's not due to that.
    this issue only happens yesterday, btw I have been using this version for 1 year.
    if it is due to RTL change or constraint, it should report in fitter or mapper not sta phase.
    anything I can check?​
    AnandRaj_S_Intel
    Try deleting db and work folder and check once.
    Can you attach the project ?
    Which will help me to recreate the scenario.
    Anand Raj Shankar
