8 years agoout of memory in 17.0 compiler
Dear All, I have a Nallatech 385A board and both SDKs 16.0 and 17.0. I was always successful to compile my kernels with SDK 16.0, but when I move to 17.0 I get out of memory error: *** F...
8 years agoThis is interesting. Here I have tried several things and here are the issues:
1) when I try fast-compile option it works all fine and finishes properly (version 17.1.2) 2) When I try v17.1.2 with default compile mode it fails with the same error above. 3) Switching to version 17.1.0 gives me out of memory error. I'm really frustrated and confused. Is this whole set of Intel OpenCL toolkit that unstable? Without giving proper error messages? We basically have one machine with FPGAs, and a cluster of machines with Ubuntu on it. I'm using the cluster to compiler kernels in parallel. Without that, I cannot really proceed fast enough. The current issues with v17 and above completely blocked my progress. What do you could be solution for all these?
