8 years agoout of memory in 17.0 compiler
Dear All, I have a Nallatech 385A board and both SDKs 16.0 and 17.0. I was always successful to compile my kernels with SDK 16.0, but when I move to 17.0 I get out of memory error: *** F...
8 years agoThis one is failing because Nallatech's 17.1 BSP is not compatible with Quartus v17.1.2 and is made for v17.1.0. They have a note on their support lounge that you need to manually add a line to the BSP so that it becomes compatible with v17.1.1 and v17.1.2; however, in my experience, adding the note didn't also work either. You can try with Quartus v17.1.0 first. If it worked, then you can add the extra line and try with 17.1.2 and see if it works for you.
