11 years agooptical flow example Optimizer FAILED
Hi, I was trying to run the optical flow example on Sockit. When I compile the kernel with the full flow(without -c), I can generate the kernel file.(about 25mins) But if I want to run the...
11 years agoHello Shaodong
"Optimizer FAILED" message when compiling optical_flow.cl with --profile seems to be a bug in the compiler. We will work on fixing this for a future release of the compiler. Thank you for reporting it. To get estimated resource usage, make sure to supply --report option to aoc. Note that the estimated report is generated after the optimizer.
