Opening Signal Tap 2 Causes Fatal Error
Why does this happen to me?
I was using signal tap and suddenly this happened and now it happens every time I try to open signal tap and Quartus crashes.
This is the error log:
Problem Details
Error:
*** Fatal Error: Access Violation at 0X00007FFBBE7F72D0
Module: quartus.exe
Stack Trace:
0x172cf: SDR_DATA_INSTANCE::get_dom_node + 0xf (sld_sdr)
0x74b2e: SEDQ_JTAG_WIDGET::get_jtag_hardware + 0x1e (sld_sedq)
0x5d03: SLDQ_JTAG_WIDGET::on_update_hardware_combo_timer + 0x53 (sld_sldq)
0x11d700: QMetaObject::activate + 0x520 (QtCore4)
0x120c59: QObject::event + 0x69 (QtCore4)
0x22c55: QApplicationPrivate::notify_helper + 0xf5 (QtGui4)
0x228ef: QApplication::notify + 0x17bf (QtGui4)
0x10ec4b: QCoreApplication::notifyInternal + 0x7b (QtCore4)
0x134cdd: QEventDispatcherWin32::registeredTimers + 0x59d (QtCore4)
0x1340ff: QEventDispatcherWin32::processEvents + 0xb5f (QtCore4)
0x17445: DispatchMessageW + 0x6a5 (USER32)
0x16f61: DispatchMessageW + 0x1c1 (USER32)
0x133982: QEventDispatcherWin32::processEvents + 0x3e2 (QtCore4)
0x82004: QApplicationPrivate::openPopup + 0x204 (QtGui4)
0x10bb7b: QEventLoop::exec + 0x22b (QtCore4)
0x428520: QDialog::exec + 0xf0 (QtGui4)
0x9edc7: AFCQ_MSG_DISPLAY::internal_error_display + 0x277 (GCL_AFCQ)
0x1dc81: MSG_REPORT::internal_error + 0xf1 (CCL_MSG)
0x38817: MSG_ERROR_INFO::finalize + 0x97 (CCL_MSG)
0x39234: MSG_INTERNAL_ERROR::report + 0xd4 (CCL_MSG)
0x10389: SDR_DATA_SESSION::parse + 0x1a99 (sld_sdr)
0x9871: SDR_DATA_SESSION::SDR_DATA_SESSION + 0x241 (sld_sdr)
0x8071: SDR_DATA_MANAGER::open_session + 0x61 (sld_sdr)
0x5ed12: SDR_TX_SESSION::open_session + 0x32 (sld_sdr)
0xcbd14: SEDQ_TX_MANAGER::open_document + 0x104 (sld_sedq)
0xcc60b: SEDQ_FRAME_WND::open_file + 0x9b (sld_sedq)
0x1f23e: QUI_FRAME_MGR::open_file + 0x53e (SYS_QUI)
0x625f6: QUI_TOOLS_MENU::sedq_action + 0x1b6 (SYS_QUI)
0xa09f: QAction::activate + 0xdf (QtGui4)
0x3ba703: QMenu::actionGeometry + 0x443 (QtGui4)
0x3ba595: QMenu::actionGeometry + 0x2d5 (QtGui4)
0x61b84: QWidget::event + 0xd4 (QtGui4)
0x3bb444: QMenu::event + 0x284 (QtGui4)
0x2184e: QApplication::notify + 0x71e (QtGui4)
0x25a9e: QApplicationPrivate::sendMouseEvent + 0x1de (QtGui4)
0x865b6: QScrollBar::trUtf8 + 0x10b6 (QtGui4)
0x8a301: QApplication::winMouseButtonUp + 0x2761 (QtGui4)
0x10e18f: QCoreApplication::exec + 0xdf (QtCore4)
0x198b: qgq_main + 0x8b (quartus)
0x133a8: msg_main_thread + 0x18 (CCL_MSG)
0x14bae: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16af0: mem_thread_wrapper + 0x70 (ccl_mem)
0x12c41: msg_exe_main + 0xa1 (CCL_MSG)
0x2777: WinMain + 0x127 (quartus)
0x1f40: __tmainCRTStartup + 0x148 (quartus)
0x17973: BaseThreadInitThunk + 0x13 (KERNEL32)
0x6a270: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 19.1.0
Build: 670
Edition: Lite Edition
Also when I try to recompile I get this
Problem Details
Error:
Internal Error: Sub-system: SDR, File: /quartus/sld/sdr/sdr_data_session.cpp, Line: 2105
Unexpected FIO_FILE_SYSTEM::status() return
Stack Trace:
0x1f896: ICE_CONTROL_GUI::setup_assignment + 0x356 (sld_ice)
0x2a54a: QUI_FRAME_WND::flow_starting_setup + 0xca (SYS_QUI)
0x128f1: QUI_APP::start_flow + 0x51 (SYS_QUI)
0x4e622: QUI_PROCESSING_MENU::start_compile_action + 0x62 (SYS_QUI)
0x3485b5: QAbstractButton::click + 0x135 (QtGui4)
0x349499: QAbstractButton::mouseReleaseEvent + 0x59 (QtGui4)
0x3f4e7e: QToolButton::mouseReleaseEvent + 0xe (QtGui4)
0x86940: QScrollBar::trUtf8 + 0x1440 (QtGui4)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Address bits: 64
Version: 19.1.0
Build: 670
Not sure what to do since this makes Quartus unusable
I deleted all the .stp files in the project and that fixed it
- AWrithingMassOfFlesh
- Kris
thank you, this problem was causing me grief with removing and readding platform designer files and attempting to recompile
- sstrell
Trash the db and incremental_db folders and try to compile again. Something probably got corrupted in the compilation database.
- KennyT_altera
Besides this, try to reduce some signal to be monitor.
- KennyT_altera
any update?
- KennyT_altera
We do not receive any response from you to the previous question that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
