SKon1's avatar
SKon1
6 years ago
Opening a saved Signal Tap file for viewing
Hello, I ran Signal Tap analysis and exported the waveform using the .CSV format.
At a later stage, I want to re-open the exported file inside Quartus to view the waveforms.
How can I do that ?
  • sstrell's avatar
    sstrell
    Unless you have the logging feature enabled in Signal Tap, you can't. Turn on the Data Log checkbox near the bottom of the .stp file window to automatically log and store all captured waveforms or manually save a waveform with the button that's there. You can double-click any previously captured and logged waveform from there. The waveforms are all saved in the single .stp file.
  • Hi,
    We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
    Shyan Yew
