13 years agoOpenCL SDK on Ubuntu
Hi,The OpenCL SDK Release page says that Redhat EL 5.6 is the only supported Linux distribution. We have a server with 32G RAM running Ubuntu 12.04.I am just curious to know if OpenCL SDK will run...
11 years ago --- Quote Start --- [...] In ubuntu the aocl diagnose command runs successfully but the aocl flash command fails. The error says that the hardware cable is not connected. The usb blaster cable is connected and the board is listed in the output of the 'lsusb' command. [...] Error (213013): Programming hardware cable not detected Error: quartus_pgm failed at /home/johnspaul92/altera/14.1/hld/board/terasic/de5net/linux64/libexec/flash.pl line 74, <STDIN> line 1. aocl flash: Program failed. --- Quote End --- I'm experiencing the same here. My configuration is: Ubuntu 14.04 LTS 3.19.0-25-generic DE5-Net BSP/Driver: Modified v14.0 AOCL Version: 15.0.2 Quartus II: 15.0.2 I saw that patch 0.19 for quartus ii 14.1 (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd01272015_37.html) addressed this issue but in the web page of the patch it's also written that the problem is solved in Quartus 15.0 :confused: I tried to check the files inside the patch and some of them are actually the same files in my Quartus 15.0.2. I also tried to patch my Quartus 15.0.2 (even if the patch is not made for this version) but nothing changed; the problem is still there. The good news is that aocl program tool and API calls let me program the device anyway. If somebody could help here to solve the situation it would be nice anyway, Nicola.
