13 years agoOpenCL SDK on Ubuntu
Hi,The OpenCL SDK Release page says that Redhat EL 5.6 is the only supported Linux distribution. We have a server with 32G RAM running Ubuntu 12.04.I am just curious to know if OpenCL SDK will run...
11 years agoHi,
I only have access to a machine running ubuntu (and windows). Not other versions of linux available. And i prefer using ubuntu over windows. But I am having problems with the aocl driver in ubuntu. The boards works perfectly fine in windows. In ubuntu the aocl diagnose command runs successfully but the aocl flash command fails. The error says that the hardware cable is not connected. The usb blaster cable is connected and the board is listed in the output of the 'lsusb' command. So can you please tell me how to solve this driver issues? output of aocl diagnose : aocl diagnose: Running diagnostic from /home/johnspaul92/altera/14.1/hld/board/terasic/de5net/linux64/libexec Verified that the kernel mode driver is installed on the host machine. Using platform: Altera SDK for OpenCL Using Device with name: de5net_a7 : Altera's Preferred Board Using Device from vendor: Altera Corporation clGetDeviceInfo CL_DEVICE_GLOBAL_MEM_SIZE = 4294967296 clGetDeviceInfo CL_DEVICE_MAX_MEM_ALLOC_SIZE = 4293918720 Memory consumed for internal use = 1048576 Actual maximum buffer size = 4293918720 bytes Writing 4095 MB to global memory ... Write speed: 1975.88 MB/s [1959.28 -> 1990.31] Reading and verifying 4095 MB from global memory ... Read speed: 2813.43 MB/s [2798.11 -> 2827.39] Successfully wrote and readback 4095 MB buffer Transferring 8192 KBs in 16 512 KB blocks ... 2009.26 MB/s Transferring 8192 KBs in 8 1024 KB blocks ... 2546.06 MB/s Transferring 8192 KBs in 4 2048 KB blocks ... 2742.12 MB/s Transferring 8192 KBs in 2 4096 KB blocks ... 2580.77 MB/s Transferring 8192 KBs in 1 8192 KB blocks ... 2701.07 MB/s PCIe Gen2.0 peak speed: 500MB/s/lane Writing 8192 KBs with block size (in bytes) below: Block_Size Avg Max Min End-End (MB/s) 524288 1276.34 1396.63 1201.31 1236.97 1048576 1459.67 1780.07 1378.81 1441.02 2097152 1941.49 2053.72 1825.71 1936.21 4194304 1821.83 1883.68 1763.92 1819.59 8388608 1941.08 1941.08 1941.08 1941.08 Reading 8192 KBs with block size (in bytes) below: Block_Size Avg Max Min End-End (MB/s) 524288 1744.30 2009.26 1588.37 1687.13 1048576 2424.19 2546.06 2344.27 2403.30 2097152 2693.70 2742.12 2656.59 2679.92 4194304 2506.41 2580.77 2436.22 2496.38 8388608 2701.07 2701.07 2701.07 2701.07 Write top speed = 2053.72 MB/s Read top speed = 2742.12 MB/s Throughput = 2397.92 MB/s DIAGNOSTIC_PASSED output of aocl flash : aocl flash: Running flash from /home/johnspaul92/altera/14.1/hld/board/terasic/de5net/linux64/libexec ========================= Page Selection ========================= Please select the flash page where to store your FPGA configure data: [0] Factory Image Location(Address 0x00040000), SW5.2 = "1" (Right Position) [1] User Image Location(Address 0x020C0000), SW5.2 = "0" (Left Position) Enter a digital number 0 or 1 (Or other values to exit the program) followed by pressing the "Enter" key: 1 Flash Programming... Info: ******************************************************************* Info: Running Quartus II 64-Bit Convert_programming_file Info: Version 14.1.0 Build 186 12/03/2014 Patches 0.19 SJ Full Version Info: Copyright (C) 1991-2014 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus II License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Tue Aug 25 11:07:47 2015 Info: Command: quartus_cpf --convert flash.cof Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed! Info (210033): Memory Map File flash.map contains memory usage information for file flash.pof Info: Quartus II 64-Bit Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 884 megabytes Info: Processing ended: Tue Aug 25 11:08:24 2015 Info: Elapsed time: 00:00:37 Info: Total CPU time (on all processors): 00:00:34 Error (213013): Programming hardware cable not detected Error: quartus_pgm failed at /home/johnspaul92/altera/14.1/hld/board/terasic/de5net/linux64/libexec/flash.pl line 74, <STDIN> line 1. aocl flash: Program failed.
