12 years agoOpenCL SDK can't find valid license file
I'm getting whenever I try invoke the kernel on certain build server: Error: aoc: Can't find a valid license for the Altera SDK for OpenCL I've definitely set LM_LICENSE_FILE correctly - ...
11 years agoHi,
I would recommend opening a service request with Altera to get help on how to set up your license file in your system Some issues I have come across in the past: (1) trying to use a fixed node license as a floating license (or the opposite) - the license file format is different (2) if you are trying to use a version of Quartus which is newer than the Subscription Expiration date of your license then that will not work either Thanks
