10 years agoOpenCL SDK 15.0 not opening
I have downloaded 15.0 FPGA design and SDK for openCL. Istallation process done, but just quartus is working and for OpneCL SDK terminal open for a second and close by it self. I am not able to op...
10 years agoLet me give you all Detail:
My PC has below system properties: OS : Windows 8 Pro RAM: 4 GB System type:64 Bit, X-86 based processor. Now as per manual, Devloper need 24 GB RAM, So in this case am I work as devloper? If yes then Do I need 24GB RAM? I have installed Quartus and Altera Open CL SDK , didnt get any error during installation. Quartus is working fine but OpenCL is not working. e.g. I click on Open CL program , it opens with a terminal window for a msec and close it byself. I checked in installed program, and OpenCL SDK is there. One more thing I would like to clarify is, I will write C code for FPGA board and using OpenCL SDK I will be able to load program in to FPGA board, Am I understand correct? Just for Info: I havent connected any FPGA board with my Pc. Is it okay to work on OpenCL without board? Thanks for reply.
