9 years agoOpenCL library example1 - aocl-opt error
Hello!
I am interested in packaging VHDL code as a part of OpenCL library. I am trying to run the examples listed on the website https://www.altera.com/support/support-resources/design-examples/design-software/opencl/library-design-example.html This is specific to example 1, but I get the same error for example 2 as well. I have followed the steps in the Readme.html present in the package. dg252267@is231451:/local2/library_example1/device/lib1$ ls
c_model.cl div double_lib.aoclib double_lib.aoco double_lib.h double_lib.xml dspba_library rsqrt sqrt
dg252267@is231451:/local2/library_example1/device/lib1$ aocl library hdl-comp-pkg double_lib.xml -o double_lib.aoco
dg252267@is231451:/local2/library_example1/device/lib1$ aocl library create -name double_lib double_lib.aoco
dg252267@is231451:/local2/library_example1/device/lib1$ cp double_lib.aoclib ..
dg252267@is231451:/local2/library_example1/device/lib1$ cd ../../
dg252267@is231451:/local2/library_example1$ ls
bin device host Makefile README.html
dg252267@is231451:/local2/library_example1$ aoc device/example1.cl -o bin/example1.aocx -I device/lib1 -L device -l double_lib.aoclib --board alaric_v3_prod
aocl-opt: Too many positional arguments specified!
Can specify at most 1 positional arguments: See: /local2/is231451/intelFPGA_pro/16.1/hld/linux64/bin/aocl-opt -help
Error: Optimizer FAILED.
Refer to example1/example1.log for details.
dg252267@is231451:/local2/library_example1$ aoc -march=emulator device/example1.cl -o bin/example1.aocx -I device/lib1 -L device -l double_lib.aoclib --board alaric_v3_prod
Can specify at most 1 positional arguments: See: /local2/intelFPGA_pro/16.1/hld/linux64/bin/aocl-opt -help
I have tried the command both with and without the emulator. If I run aocl-opt - help , I get a list of available parameters that I can pass on. My issue is, the example1.cl does not use this command. And the device libraries are obfuscated code, so I cannot actually see where the aocl-opt is being called. I have tried the multi vector add example and it executed successfully. I haven't tried the other 2 examples listed as they are for v17.0 and I am using v16.1. I am targeting ReflexCES alaric Arria 10 board. I am running this example on Ubuntu 14.04. Has anyone come across this error before? I welcome any suggestions. Thank you!2 Replies
I had the same error with code I made (not from the examples form Intel). Also, I've tried the step you did with the example 1 and everything worked fine : no error. When I got this error, as strange as it could be, I only moved my code on my desktop, repeat the exact same thing as you did and it compiled. I was working from a SVN repository and a path with spaces in it. So try to move your code somewhere safe with short path, no spaces and on C drive (because I don't see any drive in the path you're using). As a difference, I am working on Windows, so it is possible that it may not fix your issue Try this and let us know if it worked ! - Altera_Forum
Hi Tibs,
Thank you for the suggestion. I did have a space in my $PATH variable and the folder name ( I had edited the path to put in the forum). Moving the code elsewhere fixed it. Thank you! :)
