9 years agoOpenCL_Library : Exemple 1 :Segmentation fault (core dumped)
Hi, I'm trying to excute the example OpenCL Library (Exemple 1) (Link Below). I generated my excutable file for My FPGA Arria 10. Then I get this message when I execute : Segmentation fault (core ...
9 years agoThank you ,
The example 1 doesn't' work and the binary file is generated successfully. Note that I'm using a Nallatech Board with Arria 10 FPGA and SDK for Opencl under Linux OS. Which debugger you use ?
