9 years agoOpenCL_Library : Exemple 1 :Segmentation fault (core dumped)
Hi, I'm trying to excute the example OpenCL Library (Exemple 1) (Link Below). I generated my excutable file for My FPGA Arria 10. Then I get this message when I execute : Segmentation fault (core ...
9 years agoSegmentation faults usually occur when the executable tries to access a memory it does not have access to and may be difficult to debug (such as accessing data past a pointer's allocated space). The example should work out of the box if the binary is generated and in the expected location for the host to find. Otherwise using a debugger would be helpful to find out where the segfault is happening.
