8 years agoOpenCL kernel takes more than 36 hours to compile on Arria 10
Dear community, Before the weekend I started the compilation of my OpenCL kernel using the Intel SDK for OpenCL for the Arria 10 FPGA board. I had compiled an unoptimized version of this kernel...
8 years agoWell, then it is really getting stuck during synthesis, which is VERY strange and uncommon. You can probably try using one of the newer or older versions of the compiler if you have a compatible BSP and see what happens. You can probably also complain to Altera, but they will likely not pay much attention unless you are using the latest version of the compiler.
