amara5
7 years agoOpenCL kernel for a DE10-standard board via OpenCL SDK 18.0.0.614 Windows 7: no top.sof file
I am trying to compile OpenCL kernel for a DE10-standard board via OpenCL SDK 18.0.0.614 Windows 7 using the command: C:\intelFPGA\18.0\hld\board\de10_standard\test\hello_world\device>aoc hello_worl...
HRZ
7 years agoA Quartus license is definitely required for compiling OpenCL kernels but this problem does not seem to be related to license. I see a lot of unnatural warning in the log:
Warning (332174): Ignored filter at top.sdc(22): altera_reserved_tck could not be matched with a port or pin or register or keeper or net or combinational node or node File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 22
Warning (332049): Ignored create_clock at top.sdc(22): Argument <targets> is not an object ID File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 22
Info (332050): create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck} File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 22
Warning (332174): Ignored filter at top.sdc(23): altera_reserved_tdi could not be matched with a port File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 23
Warning (332174): Ignored filter at top.sdc(23): altera_reserved_tck could not be matched with a clock File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 23
Warning (332049): Ignored set_input_delay at top.sdc(23): Argument <targets> is an empty collection File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 23
Info (332050): set_input_delay -clock altera_reserved_tck -clock_fall 3 [get_ports altera_reserved_tdi] File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 23
Warning (332049): Ignored set_input_delay at top.sdc(23): Argument -clock is not an object ID File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 23
Warning (332174): Ignored filter at top.sdc(24): altera_reserved_tms could not be matched with a port File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 24
Warning (332049): Ignored set_input_delay at top.sdc(24): Argument <targets> is an empty collection File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 24
Info (332050): set_input_delay -clock altera_reserved_tck -clock_fall 3 [get_ports altera_reserved_tms] File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 24
Warning (332049): Ignored set_input_delay at top.sdc(24): Argument -clock is not an object ID File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 24
Warning (332174): Ignored filter at top.sdc(25): altera_reserved_tdo could not be matched with a port File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 25
Warning (332049): Ignored set_output_delay at top.sdc(25): Argument <targets> is an empty collection File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 25
Info (332050): set_output_delay -clock altera_reserved_tck -clock_fall 3 [get_ports altera_reserved_tdo] File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 25
Warning (332049): Ignored set_output_delay at top.sdc(25): Argument -clock is not an object ID File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 25
Warning (332174): Ignored filter at top.sdc(31): fpga_button_pio[0] could not be matched with a port File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 31
Warning (332049): Ignored set_false_path at top.sdc(31): Argument <from> is an empty collection File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 31
Info (332050): set_false_path -from [get_ports {fpga_button_pio[0]}] -to * File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 31
Warning (332174): Ignored filter at top.sdc(32): fpga_button_pio[1] could not be matched with a port File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 32
Warning (332049): Ignored set_false_path at top.sdc(32): Argument <from> is an empty collection File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 32
Info (332050): set_false_path -from [get_ports {fpga_button_pio[1]}] -to * File: C:/intelFPGA/18.0/hld/board/terasic/de10_standard/test/hello_world/bin/hello_world/top.sdc Line: 32I think the problem is likely related to a bad BSP or a bad BSP installation. I would have recommended to try Terasic's older v16.0 BSP but then you are going to have use Quartus and AOC v16.0 and AOC v16.0 requires a separate license on top of the Quartus license.
