8 years agoOpenCL HostApp fails with acl_bind_buffer_to_device: Assertion `mem' failed
Hey, first some infos about the environment: Board: Nallatech 510T (2x Arria 10) Ubuntu 16.04. Quartus 17.1.0 Flashing the .aocx and compiling of the HostApp was successfull. ...
8 years agoWe talked to the author already and he sent us a newer version, but with the same issue and nearly the same code.
We added a debugging and error helpers, but can't get past the initialisation stage. The author does not respond anymore, but he said, he has a working Nallatech 510S with this code. That was the last information we received from him. I think the error has something to do with the memory release. The verbose debugging says "double free or corruption (!pref): 0x00000...124c6a0...)". The host has 32GB physical ram and our FPGA has 2 x 8GB Global Ram per FPGA Accelerator (Nallatech 510T with 2x Arria10). Maybe it has something to do with host memory. Do you know the error or could you tell us where we should look? Thank you! PS: hello_world and stuff like that is working without any issue.
