10 years agoOpenCL Emulator with Parallel Kernels and Channels
When using more than 3 parallel kernels that are interconnected with channels I get strange behavior in the during emulation. The kernels don't seem to actually run in parallel which causes deadlocks...
10 years agoI've researched the issue some more and distilled it down to simpler code:
__kernel void in_streamer_a(__global const uint2* in) {
printf("in streamer a start\n");
for(uint i = 0; i < SIZE; ++i) {
write_channel_altera(in_channel, in);
printf("in streamer end start\n");
__kernel void in_streamer_b(__global const uint2* in) {
printf("in streamer b start\n");
printf("in streamer b end\n");
__kernel void out_streamer(__global uint2* out) {
printf("out streamer start\n");
ushort4 value = read_channel_altera(out_channel);
out = value;
printf("out streamer end\n");
__kernel void worker()
printf("worker start\n");
write_channel_altera(out_channel, read_channel_altera(in_channel) + read_channel_altera(in_channel));
printf("worker stop\n");
When I run all kernels in the emulator with a small SIZE parameter, i get the correct result and the following console output
in streamer a start
in streamer a stop
in streamer b start
in streamer b stop
worker start
worker stop
out streamer start
out streamer stop
The kernels are run sequentially and the intermediate results are buffered in a channel buffer as it seems. This fits well with the official altera documents. However, when I use a large SIZE argument (10240 or more to be precise), I get the following output and a deadlock:
in streamer a start
Only the first kernel is ever run. It just hangs there. It could be that some internal buffer for the used channel is full, but I don't know of any way tho change its size. Maybe it's something else. Using the following channel attribute does not help:
__attribute__((depth(SUFFICIENTLY_HUGE_NUMBER)));
Note: everything works perfectly fine on the device, where the kernels are actually run in parallel.
