9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
Hi, when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl scr...
9 years ago@tury, it is best if you start your own thread. You should attach the full "quartus_sh_compile.log" file. Is your BSP compatible with the version of Quartus you are using?
