9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
Hi, when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl scr...
9 years agoYour compilation log looks very strange, there are lots of warning in it that I have never seen before, especially the parts that complain about some files having been edited in Quartus 15.0. Have you tried completely removing the OpenCL project folder as yangchen4623 suggested and then running your AOC command?
Also please mention your board name. Your BSP version should be something that matches some version of Quartus (like 14.0/15.0/16.0, etc). You might be using a BSP that is not compatible with the version of Quartus/AOC you are using.
