9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
Hi, when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl scr...
9 years ago --- Quote Start --- Does this issue happen with all of your kernels or just some? If it happens with all, you should probably contact Gidel since there might be some issue with their BSP. If it is just some kernels, can you also post the kernel compilation log if it exists? It is named *kernel_name*.log? --- Quote End --- I checked the "kernel_name".log file, but couldn't find any error message. I actually solved the problem but deleting the previously generated Quartus project. It seems that a previous build error existed in the generated Quartus project failed all of my later complies.
