9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
Hi, when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl scr...
9 years ago --- Quote Start --- Thank you for the quick reply. The board I'm using is Gidel Proc10A X115 which has an Arria 10 FPGA on. The BSP is the most update to date one which supports the Quartus Prime version 16.0.2, which matches the Quartus version I'm using. --- Quote End --- Does this issue happen with all of your kernels or just some? If it happens with all, you should probably contact Gidel since there might be some issue with their BSP. If it is just some kernels, can you also post the kernel compilation log if it exists? It is named *kernel_name*.log?
