9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
Hi, when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl scr...
9 years ago --- Quote Start --- When I run "quartus_map --version", it shows "bash: quartus_map: command not found...".How to add it to my PATH? Thank you! --- Quote End --- Add this to your bashrc (Replace *install_folder* with correct path):
PATH=$PATH:*install_folder*/quartus/bin
