9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
Hi, when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl scr...
9 years agoThe log doesn't say much in your case, it seems Quartus is failing when it is trying to import the base design from the BSP. Is your BSP up-to-date? What board and BSP version are you using?
