9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
Hi, when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl scr...
9 years ago --- Quote Start --- This is really strange if you can actually compile using such vastly different versions of Quartus and AOC. Do you have multiple versions of Quartus installed on your machine? If that is the case, you can change the default version by modifying the PATH variable from the Environmental Variables. If not, make sure to install the latest versions from Altera's website and then correct your environmental variables. Make sure to fully read this document: https://www.altera.com/en_us/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf --- Quote End --- I have installed the latest version of AOC from Altera and set all the related user environment variables to point to that version. I attached my compilation log.
