9 years agoOpencl complie Error: Evaluation of Tcl script import_compile.tcl unsuccessful
Hi, when I complie my kernel, export "Error: Compiler Error, not able to generate hardware". When I chaeck the file "quartus_sh_complie.log", it only says"Error (23031): Evaluation of Tcl scr...
9 years ago --- Quote Start --- Please post the full compile log and also the version of Quartus (quartus_map --version) and AOC (aoc --version) you are using alongside with your board model and BSP version. Such error is generally caused by discrepancy between version of Quartus and AOC or between version of AOC and BSP. --- Quote End --- Thank you for reply! "quartus_map --version" cannot printf out quartus version. Most of time, complie result is right, so I think it's not the mismatch of Quartus and AOC version.Is it right? Because complie file has 14259 rows, so I cannot post it. At the end of file,it only says: "Error (23031): Evaluation of Tcl script import_compile.tcl unsuccessful Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 3734 megabytes Error: Processing ended: Tue Apr 18 07:42:37 2017 Error: Elapsed time: 05:29:19 Error: Total CPU time (on all processors): 12:40:38" I don't find any error message in other place of the file.
