OpenCL Compiler Local Memory Address Space Splitter fails
- 7 years ago
Thank you for your reply, AKert. It is great to hear that my report is of some value. Meanwhile, I have found that the issue seems to be caused by reading from global memory and writing to an Intel FPGA channel in a single statement. When replacing
UTL_WRITE_CH(ch_1, data1[j]); UTL_WRITE_CH(ch_2, buf_d2[i]);with (make sure to use the actual types)
const my_type1 temp1 data1[j] UTL_WRITE_CH(ch_1, temp1); const my_type2 temp2 buf_d2[i] UTL_WRITE_CH(ch_2, temp2);the error goes away. It may or may not be related to also using char (8 bits) buffers.
I created a minimal (non-)working example: https://pastebin.com/3j6my0YA. Can anyone confirm that this crashes the compiler in 16.1 and 17.1 (possibly other versions, too)? Does anyone have an idea what could be the problem in this code? Keep in mind that this is an artificial example and does not really need the buffers etc. that are being created, nor do the operations make much sense...
