8 years agoopencl compile error
Hi, I'm a student who has the problem with compiling openCL.
my Quartus and Altera OpenCL SDK version is 16.0 What the problem is that if i try to compile such as : aoc device/boardtest.cl --sw-dimm-partition -o bin/device boardtest.aocx the Error message shows like that Error: aoc: Executable C:/altera/16.0/hld/windows64/bin/aocl-clang exists but is not working! The cause of failure cannot be determined. Run executable manually and watch for error message. I set the User Environment variable, License, and reinstalled the application. but I have the same error message. Is there anyone else who have the same problem like me? https://alteraforum.com/forum/attachment.php?attachmentid=14421&stc=12 Replies
could you check the user permission and access right? If you try to compile a normal Hello world. is that works? Regards, CloseCL (This message was posted on behalf of Intel Corporation) - Altera_Forum
I already checked the user permission and access right.
also, I use command prompt(Administrator), but it doesn't work.. I don't know what the problem is
