8 years agoOpenCL compile error for high resource utilization
Hello, I encounter compile error (Error (23031): Evaluation of Tcl script import_compile.tcl unsuccessful) when my resource utilization is huge. My estimated resource usage is : +---------...
8 years agoWell, the error message is far from informative and the process is failing pretty early in the chain before even reaching placement and routing. 20 GB of memory is certainly not enough for large Arria 10 designs; however, this might not necessarily be the source of your problem right now. Can you clarify what board and what BSP you are using?
