liyu
7 years agoOpenCL BSP for Intel Cyclone 10 GX
We bought 2 Cyclone 10 GX for prototype purpose, and in terms of the official site it "suppose" to support OpenCL FPGA SDK kit and OpenCL is the selling feature for this product, however, Quartus pri...
DongWang-BJTU
7 years ago18.1 version has the bsp for c10gx, you can find it under the directory intelFPGA_pro/hld/board.
liyu
7 years agoThanks for the reply could you confirm this bsp support opencl sdk kits?
- DongWang-BJTU7 years ago
checkout this
- liyu7 years ago
Thanks, probably we r using Windows something is missing, I will try out Linux version later
- Abe7 years ago
Have you downloaded and installed the Intel OpenCL SDK and platforms for your board?
- lking37 years ago
Thanks. I've installed the AOCL Pro 18.1 for windows, and found the directory "intelFPGA_pro/18.1/hld/board/c10gx" ,but there were only a "hardware" directory and an empty board_env.xml file in it, no other directories. And when I run the aocl install command,it shows:"no board installation routine supplied". Have you ever met the problem?
