10 years agoopencl aocl diagnose failed
hi, I installed the opencl SDK version 15.1. my chip is arria 10(10AX115N4F40I3SGE2) When I typed the command aocl diagnose , there are some message happended.
:: Init: Bar 4, Total ...
9 years agopls check your environment variables and your hardware
--- Quote Start --- I met the same issue when using OpenCL SDK 16.0, aocl diagnose simply cannot diagnose the device driver but lsmod shows that the driver is already in used. I have tested with two different OS but the same error happened. Have you solved this problem already? --- Quote End ---
