OK, here is another example. A prison door(far from all vhdl designers) requires a secret code to unlock.
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.std_logic_unsigned.all;
ENTITY door_key IS
PORT (
d : in STD_LOGIC_vector(15 downto 0);
clk : in STD_LOGIC;
q : out STD_LOGIC);
END entity;
ARCHITECTURE rtl OF door_key IS
BEGIN
PROCESS (clk)
BEGIN
IF rising_edge(clk) THEN
if d = x"1234" then
q <= '1';
else
q <= '0';
END IF;
END PROCESS;
END rtl;
I am sorry you may have English language difficulty, if you can explain what is the requirement then we may help better.
