LucaGiambastiani
6 years agoOn-chip memory on Stratix 10
We are porting a project from Arria V (Quartus 16.1) to Stratix 10. The original one used the on-chip RAM memory IP with dual clock and Avalon-MM interfaces. It appears that this type of IP ...
SyafieqS
6 years agoHi Luca,
Yes, there is a feature in S10 so called True Dual Port Dual Clock Emulator (TDP) to emulate TDP dual clock mode. You must turn on this feature in parameter editor of dual-port RAM IP core. May refer to link below for details
LucaGiambastiani
6 years agoHello Syafieq,
Thanks for the reply.
We think that there are two problems with the TDP emulator. First, we need a memory with Avalon-MM interfaces, while the dual port RAM seems to have only conduit interfaces. Second, the page you linked says that the latencies are not guaranteed with a clock ratio less than 7. In our case the frequencies are 220 MHz and 250 MHz, so a ratio way below 7.
Is it possible to configure this IP component in a way that is compatible with an Avalon-MM interface?
Luca
