sagarsonavaneBH
5 years agoOn chip ADC hangs up in 10M50DAF256I76
We are using the part 10M50DAF256I76 in one of our designs. In this design we are using the available on chip modular dual ADC. The interface for the ADC is generated inside QSYS with the following ...
sagarsonavaneBH
5 years agoWe are using single cycle conversion mode. We setting bit 0 and bit 1 of ADC command register to 1.
sstrell
5 years agoIf you're setting bit 0 to 1 (the run bit), as stated in that table, that overrides the single cycle mode. If you want single cycle, the register should be set to 0x2 (run bit set to 0).
