8 years agoOdd behavior with matching-case (vhdl 2008)
Hello! I'm trying to use the matching-case syntax introduced in vhdl 2008 but I'm having a bit of a problem. Take the following piece of code, say a register map for example: clk : in ...
8 years agoI would raise this as a synth bug to altera, as you will now have a simulation/synthesis missmatch.
Any chance you have a Prime pro license? Prime pro is meant to have full vhdl 2008 support, so I assume a different compile engine.
