Not seeing Installed Devices
Can we get an update on this? I am running into the same problem. If we are still waiting for a license, will Arria 10 show up in the available devices for the "New Project Wizard" ? Or do you need a license for it to even show up in the New Project Wizard"?
If the device won't show up in the wizard due to licensing, there should be a warning to developers that this is the issue and not that we installed the software incorrectly.
Quartus Pro is a 50GB download and then an hour+ install. Uninstalling and reinstalling is a poor solution that seems to be thrown around as if it is acceptable. It is disappointing for a company that charges as much as it does for its products, and then even more for licenses to use the products that were already bought, to deliver this quality of work.
It has nothing to do with licensing. The installer is way better now than it was in 2018 (when this thread is from; probably should start a new one and link to this if you want to).
So you're saying that you've installed Arria 10 devices along with Quartus and you can't select them in the New Project Wizard? Did you use the new all-in-one installer or download individual files?
