13 years agoNot entering IF statement
Hello;
synopsys: Moore state machine, 2 processes executed concurrently. The first process determines current state/next state. The second process determines outputs. problem: when the state machine is in the state "ADD_PILL_TOTAL" in the first process the outputs are not changing as per the "ADD_PILL_TOTAL" statement in the second process, It is not entering this statement at all. It enters all the other states and outputs properly in all other cases. What I have tried: The commented out lines in the first process perform the function that I want and the state machine works the way I want it to when those lines are enabled and the corresponding lines in the second process are disabled. PROCESS( StateMachineStart, StateMachineStop, StateMachinePillEqual, StateMachinePillDetected, StateMachineBottleDetected, Current_State) BEGIN Next_state <= Current_state; -- BottleCounterEnable <= '0'; -- TotalPillCountStoreEnable <= '0'; if (Current_state = IDLE) then if (StateMachineStart = '0') then Next_state <= POSITION_BOTTLE; else next_state <= IDLE; end if; elsif (Current_state = POSITION_BOTTLE) then if (StateMachineBottleDetected = '1') then Next_state <= DISPENSE_PILL; else Next_state <= POSITION_BOTTLE; end if; elsif ((Current_state = DISPENSE_PILL)) then if (StateMachinePillDetected = '0') then Next_State <= PILL_DETECTED; else Next_State <= DISPENSE_PILL; end if; elsif ((Current_state = PILL_DETECTED)) then if (StateMachinePillDetected = '1') then Next_state <= ENABLE_PILL_COUNT; else Next_state <= PILL_DETECTED; end if; elsif (Current_state = ENABLE_PILL_COUNT) then Next_state <= DISABLE_PILL_COUNT; elsif (Current_state = DISABLE_PILL_COUNT) then if (StateMachinePillEqual = '0') then Next_state <= DISPENSE_PILL; else Next_state <= ADD_PILL_TOTAL; end if; elsif (Current_state = ADD_PILL_TOTAL) then Next_state <= ADVANCE_NEW_BOTTLE; -- BottleCounterEnable <= '1'; -- TotalPillCountStoreEnable <= '1'; elsif (Current_state = ADVANCE_NEW_BOTTLE)then Next_state <= POSITION_BOTTLE; end if; END PROCESS ; PROCESS (Current_state, Next_state) BEGIN BottleCounterEnable <= '0'; TotalPillCountStoreEnable <= '0'; PillCounterClear <= '0'; PillCountEnable <= '0'; OpenValve <= '0'; AdvanceConveyor <= '0'; if (Current_state = IDLE) then PillCounterClear <= '1'; elsif (Current_state = POSITION_BOTTLE) then AdvanceConveyor <= '1'; elsif (Current_state = (DISPENSE_PILL OR PILL_DETECTED OR PILL_NOT_DETECTED) ) then OpenValve <= '1'; elsif (Current_state = ENABLE_PILL_COUNT) then PillCountEnable <= '1'; OpenValve <= '1'; elsif (Current_state = DISABLE_PILL_COUNT) then OpenValve <= '1'; elsif (Current_state = ADD_PILL_TOTAL) then BottleCounterEnable <= '1'; TotalPillCountStoreEnable <= '1'; AdvanceConveyor <= '1'; elsif (Current_state = ADVANCE_NEW_BOTTLE) then PillCounterClear <= '1'; AdvanceConveyor <= '1'; end if; END PROCESS; END;
