11 years agoNode instance instantiated with unknown parameter
I updated the settings of FIFO through MegaWizard and clicked Finish to generate the needed files (including DATA_FIFO_inst.vhd). https://www.alteraforum.com/forum/attachment.php?attachmentid=8888 The 'DATA_FIFO_inst' is used as a component in anther vhd file (file is attached) By running the compilation, I am getting the following errors --- Quote Start --- Error (12077): Node instance "DATA_FIFO_inst" instantiated with unknown parameter "intended_device_family" Error (12077): Node instance "DATA_FIFO_inst" instantiated with unknown parameter "lpm_numwords" Error (12077): Node instance "DATA_FIFO_inst" instantiated with unknown parameter "lpm_showahead" Error (12077): Node instance "DATA_FIFO_inst" instantiated with unknown parameter "lpm_type" Error (12077): Node instance "DATA_FIFO_inst" instantiated with unknown parameter "lpm_width" . . --- Quote End --- Can some body explain to me why? (taking into consideration that the parameters are correct!)
