11 years agoNo PLL output on modelsim
Hi all, I am using quartus 2 9.1 sp2. I want to run an ALTPLL considering only one input (Clk) and two output ( c0 and locked output). I have generated the vhdl file for modelsim. I simulate it w...
11 years agook that's weird. I used megawizard to create a pll block using Quartus 13.1. The top lines in the vhdl code are:
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY altera_mf; USE altera_mf.all; perhaps you should upgrade your quartus version. You don't need the subscription version, use the free one. I'll try doing the modelsim simulation as well.
