13 years ago --- Quote Start --- A process otherwise produces combinatorial circuit or latches --- Quote End --- Yes. I agree with you that a process creates latches, although a register is a set of latches. In any case, the problem with subtraction operation remains. The tool cannot identify the paths between the output and the input. Is it somehow possible to set the paths manually?
