13 years ago --- Quote Start --- When I remove subtraction operation from the formula, everything goes nicely. Hence, it somehow depends on the subtraction operation. --- Quote End --- I can't confirm the observation. The problem in the original design is created as follows: Read_Write is an internal self generated signal, that can't be referenced in timing analysis. Thus both the input to Read_Write as well as the Read_Write to output timing can't be analyzed. Altera timing analysis doesn't recognize, that Read_Write actually violates minimum pulse width and maximum frequency limits and valid design output can't be predicted.
