15 years ago
No Nios II target connection paths were located error in NIOS II EDS 10.0
Using Windows Xp, I upgraded Quartus II (32bit) and Nios II EDS from version 9.1SP1 to 10.0 and now I have a problem in connecting to the NIOS II processor through the JTAG USB Blaster.
Running the configuration in NIOS II EDS, when I go "run as --> Nios II Hardware", in the "Target Connection" Tab I get the message:
" no nios ii target connection paths were located. check connections and that a nios ii .sof is downloaded."
This happens even with the Terasic Cyclone III FPGA starter kit board downloading their reference design "cycloneiii_3c25_start_niosii_standard.sof" and creating an "Hello World" application program.
Is there anybody who had the same problem with NIOS II EDS 10.0 and can help me?
Michele
    I just fixed my problem using the NIOS II 10.0 Command Shell. I report what happened as someone could find it useful:
    I tried to connect to the NIOS II processor using:
    nios2-terminal
    but the shell prompted that I had to specify the --cable option as it appeared I had more than one cable active. So I enumerated my JTAG cable using:
    jtagconfig --enum
    and I discovered that it was seeing a ByteBlaster cable that I am actually not using:
    bash-3.1$ jtagconfig --enum
    1) ByteBlaster [LPT1]
    Unable to lock chain (Bad port name)
    2) USB-Blaster [USB-0]
    020F30DD EP3C25/EP4CE22
    I deleted this cable by using the command:
    jtagconfig --remove 1
    and now I can see my NIOS II processor and run my firmware on NIOS II EDS again! :)
    Michele
    Thank you very much Michele.
    We had the same problem and your fix solved it. :)
    Slobodan.
    You are very welcome Slobodan. I am happy my post was useful.
    Thank you very much for the feedback !
    Kind regards,
    Michele
