No file related to error when running functional simulation.
Thank you for your response. Did you run a full compilation of your project on Quartus before running the simulation? Make sure you compile it first.
Otherwise, why don't you try delete the db folders from your project and start a new simulation? If that does not work, try changing your EDA settings from "Modelsim-Altera" to "None" so that the RTL simulator will choose automatically.
Let me know if this helps.
Nurina
- JohanL5 years ago
I did run a full compilation before running the simulation. The compilation is successful, though there are 93 warnings.
I have tried deleting the db folder and starting a new simulation. I did not change the EDA settings. I do believe this has given me new errors which is nice as it is hopefully a sign of progress.
Now, you're talking about the RTL simulator, but I want to do a vector waveform simulation. Are these connected? Sorry I do not know exactly how things are related in Quartus.
I have attached the "new" errors below and I will look into them more tomorrow, but for now I must sleep.
Thank you again for your continued help.
